351 Mustang
more 351m help!!
Old Jan 19, 2008 | 01:10 AM
351mustang's Avatar
351mustang
Default more 351m help!!
someone here locally is sellin some 351c 2v heads...and i was wondering would these increase any bit of performance on my 351m?? if ne one knows or has an opinion on this (other than to get a 351w/c) lol..id appreciate it
Old Jan 19, 2008 | 09:30 AM
my77stang's Avatar
my77stang
Default RE: more 351m help!!
nope, 351C 2v heads are identical to 351m heads.
Old Jan 20, 2008 | 06:47 PM
S351R13's Avatar
S351R13
2v heads and m heads are not all the same. M heads are all all open chamber. 2V heads usually have a smaller chamber.
Old Jan 20, 2008 | 07:26 PM
my77stang's Avatar
my77stang
sorry bub, 2v cleve heads are ALL open chamber. the only closed chamber cleve heads were the 4v's and the aussies which were 4v chambers with 2v ports.
Old Jan 21, 2008 | 02:04 PM
S351R13's Avatar
S351R13
Hate to burst your bubble but 2v C heads have a smaller chamber than a M-head. 76 versus 78 CC.The aussie heads are 2v heads. Not 4 v heads with 2v ports.They don't have 4v valves in them. M-heads also have more material in the exhaust side forthe emissions bump than a 71-72 2V C head. Please do your research before passing out bad info.
Old Jan 21, 2008 | 03:23 PM
my77stang's Avatar
my77stang
a) a 76 vs 78 cc chamber is virtually identical. straight from ford various heads with the same casting numbers are common to be a few cc's off.
b) the aussie heads everyone talks about are the closed chamber heads like the 351C 4v but with runners like the 351C 2v heads. if you really want to get techincal there were a few flavors of the aussie heads, and some DID have the smaller valves and open chambers, but those are not the heads anyone used when "upgrading" to the aussies.
c) i'd have to look in the ports to see about the the ex bump, either way anyone redoing a set of C or M heads should be cleaning those up.
now, are you going to sit here and tell me that he would gain a performance increase worth swapping heads, if any performance increase AT ALL? you could build a 2 identical motors using the 2v 351C or the 351M heads and nobody would EVER be able to tell the difference.
Old Jan 21, 2008 | 06:41 PM
S351R13's Avatar
S351R13
An "aussie" 2V head is a small valve closed chamber head with that doesn't have the smog bump in them. They do have the 4V head down under. The do have differing heads just like we do but, the ones we get stateside are the early closed chamber ones. If one wants to build a C motor then the aussies still have alotof parts that we don't get here. The only issue is that the cost to import them doesn't make them a decent value. They also pay alot more for parts there. I've driven a Falcon XBGT before. Very impressive. Boss 351, toploader, 3.00 gear. Most of ther tech that they have done is available here though. The Cleveland has been pretty much the only thing down there for years. They still have very few Windsor parts there at all. It has to be imported for the most part. Most trying to get performance out of a M would notice the difference because of the level of performance attainable on a budget.
Old Jan 21, 2008 | 07:12 PM
my77stang's Avatar
my77stang
the whole point of this thread was is a guy with 351M heads would see a bump in power from swapping his stock heads with 351C 2v heads. the answer is no. the reason is because the heads are *virtually* identical.
Sparkiewalt
Nov 19, 2013 08:19 AM
vipergtrdj
351 Mustang
Mar 13, 2008 07:08 PM
VigCS
Sep 25, 2006 09:59 PM
73Cleveland
Oct 11, 2005 08:33 PM
djpritchard
Jul 28, 2005 04:13 PM
