351 Mustang
curious about stroker assemblies
Old Oct 25, 2008 | 11:28 PM
ddlyspdr's Avatar
ddlyspdr
Default curious about stroker assemblies
i have a plan in the works for a 351w swap. it will be turbo charged (probably 10lbs first). i am curious a 4"stroke crank will yeild around 408CI?? i was wondering what piston do i run. a stock style piston, or do i need a custom sized piston??
Old Oct 26, 2008 | 12:28 AM
dudeboy's Avatar
dudeboy
The piston diameter will depend on what kind of shape your block is in.
If the bores are clean at .030", then there's no need to go any larger.
As for the other piston specs... that will depend on the rest of your rotating assy.
Even in a 408w, there are a couple of pistons that can work depending on the rod length used.
Check some of the combos listed at the following site to get a feel for the factors...
http://www.probeindustries.com/Pisto..._351W.htm#Dish
What block are you planning to run with that boost?
Old Oct 26, 2008 | 12:45 AM
woodsy's Avatar
woodsy
Heres a quick run down of the typical rod and crank used
4.00 inch crank 6.125 rod 1.350 compression height piston
4.00 inch crank 6.200 rod 1.280 compression height piston
4.00 inch crank 6.250 rod 1.235 compression height piston
If none of that makes sense call someone who can help you. I hear these guys are ok
http://www.fordstrokers.com
lol
Old Oct 26, 2008 | 01:38 AM
glaranotch's Avatar
glaranotch
woodie your a beast
Old Oct 27, 2008 | 07:38 PM
mwood's Avatar
mwood
yah, buying a complete assembly takes the guess work out of it. Then again, there's always shortblocks. Woody can help you there too.
daltron
Apr 28, 2016 08:10 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
mltdwn12
Sep 23, 2015 08:54 AM
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
