What should I expect
we got my headers to work with little to no work. we might have had to massage them around the steering shaft a little, but other than that i didnt have any problems (for about a month until the motor came out. ill throw them on again this weekend when im home and see if i can see anything but i cant remember having any problems.
the shifter base is different on a TKO/3550 vs a T-5 i think (i went T56 so i dont really know) so if you cant take the tranny out you can just pull up the shift boot and take a look there.
on a semi related note, anyone know of a company that makes SN95 headers that are 1 3/4 into 3 inch? i know bassani makes a set, but they cost a small fortune and i cant find out what size the collector is.
What is the difference between the "track heat" intake that you are selling and the "R" intake that I have????
track heat is a manifold designed for 302 that work between 1500-6500 rpm. the R series is better suited for 351W or stroker applications.i dont know if they make the track heat for the 351W (the lower manifold is wider for the 351W vs the 302).
treesloth
09-28-2015 07:03 AM
