351 Mustang
stock bottom end 351 questions
Old Mar 25, 2010 | 08:02 AM
Black89LX's Avatar
Black89LX
Default stock bottom end 351 questions
I did a search and found nothing… what I want to know is what heads would be best for a street/strip 351 on pump gas? would the AFR 205 be overkill for my setup?
I am going with a 75mm mass air and throttle body, Typhoon upper and lower, 30 lb injectors and Im leaving the bottom end stock for now. (any suggestions are appreciated)
Another thing I need help with is deciding what to do with my valvetrain. This motor is out of a ‘90 f-250, so it doesn’t have the roller setup. So, what lift can I get away with and not have to notch the pistons for clearance?
For you guys out there with the stock bottom end, what rocker ratio and cam are you running?
Old Mar 25, 2010 | 11:31 PM
wildcobrar's Avatar
wildcobrar
TFS Fast as Cast 190 cc heads will allow you to run more lift and you will have a pretty good head for the $$$
Joe
Hogquad
Aug 23, 2015 05:26 AM
Mustangs of Illinois
Aug 22, 2015 10:00 PM
ding56
Aug 14, 2015 02:40 AM
ccwebb
Aug 11, 2015 06:47 PM
89blueslug
Aug 10, 2015 07:20 AM
