351 Mustang
393 balancing issue please help
Old May 17, 2010 | 04:01 PM
luigirox's Avatar
luigirox
Default 393 balancing issue please help
Took my crank rods pistons flywheel balancer 28 ounce, over to the shop to get balanced and the shop after 2 weeks says I need a 50 ounce flywheel and 50% harmonic balancer to get it to balance
With the balancer I gave him and the fly wheel it would take 128 grams to balance it
Old May 17, 2010 | 04:09 PM
luigirox's Avatar
luigirox
[QUOTE=luigirox;7008130]Took my crank rods pistons flywheel balancer 28 ounce, over to the shop to get balanced and the shop after 2 weeks says I need a 50 ounce flywheel and 50% harmonic balancer to get it to balance
Any help would be great
Old May 19, 2010 | 09:17 PM
Shaun351's Avatar
Shaun351
As far as I know if your harmonic balancer and flywheel are 28oz., the machine shop shouldn't have a problem balancing your parts unless one of them is damaged or the shop is unaware that your doing a windsor 351 base and not 302.
Old May 19, 2010 | 09:25 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
What brand crank is it???
When I had my stock rod 393 balanced, it took 150 bucks in weights to get it to balance. It was a 28oz. balance and a Scat crank.
Old May 20, 2010 | 06:59 AM
luigirox's Avatar
luigirox
Well I heard from some other people that build a 393 that its normal,
That the balance shop will balance it to the easiest balancer,
As long as the they are both the same, Just struck me as a suprise and now I am out the cost of the balancer and flywheel,
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Bokeo
Oct 10, 2015 08:28 PM
