stroker
Old Nov 12, 2006 | 01:27 PM
Pyrat's Avatar
Pyrat
Default RE: stroker
ORIGINAL: Denny Carlton
Whats the different between regrind and new? Is it that they use a bigger cam and grind it down to fit our car.
My understanding is that the hardening process used on the cam lobes surface is better on a billet cam than on a regrind. While I could not find a definitive statement regarding this difference, here are some term definitions from Tighe Cams which will help demonstrate the difference.
Billet Cam: This is the term for a camshaft made from a solid piece of cast iron or steel bar. 99% of steel camshafts are made this way.
Regrind
: Term used when a worn camshaft is reprofiled to the same profile or modified to a different profile. To achieve this the bulk of the shaft may need undercutting to keep the base circle above the shaft diameter.
Rockwell Hardness
: The type of hardness testing used to check the hardness of most hardened materials. Rockwell C process uses 120deg diamond with a weight of 150kg. of preload on it. This is loaded into material, and depth of the indent is measured . The result of this is given in a Rockwell C measurement.
Flame Hardening: This is a hardening technique using oxy/acetylene torch to heat a camshaft to a cherry red which is then quenched in a water based coolant.
Induction Hardening
: An electrical process of heat treating, where a camshaft is passed through a coil, through which a high frequency current is passed. The camshaft inside the coil is quickly heated to a cherry red and quenched in oil. Ivan Tighe Engineering hardens all new camshafts using this process.
Here's the source of the above: http://www.tighecams.com.au/camtypes.htm
Old Nov 12, 2006 | 02:44 PM
rygenstormlocke's Avatar
rygenstormlocke
Default RE: stroker
Thats the best definition I have seen to date IMO.
Old Nov 12, 2006 | 05:10 PM
Denny Carlton's Avatar
Denny Carlton
Default RE: stroker
Thanks for the information, that is very enlightening.
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
kevin02
39
May 22, 2004 01:39 PM
95_GT_Stang
Apr 10, 2004 04:39 PM
