View Poll Results: 7.5 or 8.8
7.5 Tlock
25.00%
8.8 Reareand
75.00%
Voters: 12. You may not vote on this poll
8.8 or 7.5
Old Aug 28, 2008 | 10:15 AM
  #21
157dB's Avatar
157dB
Cut & Paste Expert
Go GT take-off 8.8 with the T-Loc
Old Aug 28, 2008 | 02:05 PM
  #22
mustangman02232's Avatar
mustangman02232
Originally Posted by BWfVA
Bump, and just to let you know as far as your Tlock to Posi theory that is busted because I know that Chevy that have Posi is a full time Posi
posi is GMs term for limited slip, stock cars have an open diff, they deliever power to both wheels until one tire loose traction, then 100% of the power is delivered to that one wheel
a Limited slip diff (aka tlok, posi, sure-grip etc) has clutches or gears (eaton and Detroit) which splits the power between both wheels and allows one wheel to turn faster when going around corners
a locker is all gear driven and "locks" the rear wheels together, then when you turn a corner you get the loud clunking and chirping of the wheels to allow it to slip around the corner
a spool makes both rear wheels turn at the same speed regardless of what direction you are going
and if your only going to do a stock 8.8 vs build the 7.5 build the 7.5,
properly built 7.5 > stock 8.8
Matt's 95 Stang
Oct 5, 2015 07:16 AM
67LimeCoupe
Sep 30, 2015 04:46 PM
67LimeCoupe
Sep 21, 2015 06:34 PM
DCole24
Sep 11, 2015 10:50 AM
67LimeCoupe
Sep 2, 2015 08:02 AM
