spark plug removal
When you put the plugs back in, put a small amount of antiseize on the threads; that will help them go in easier and can get them out later easier.
As far as interval, IT DEPENDS ON YOUR SETUP!!! The stock plugs are supposed to last quite a while; HOWEVER, if you are running a custom tune and maybe even a CAI, you might need to check or change your plugs sooner.
After less than 30K miles, half of my plugs' were essentially wore out (electrodes worn down to much less than when new, on some plugs more than others). I started noticing some occasioanal missing out, checked/changed the plugs and it solved it.
(That was when I still had a CAI and was N/A, and running stock plugs).
[QUOTE=tx_zstang;5788514]When you put the plugs back in, put a small amount of antiseize on the threads; that will help them go in easier and can get them out later easier.
YES on the antiseize especially with the aluminum heads on our cars. If its not on there who ever gets stuck doing the next plug change might not get them out! or may take part of the head with them.
Omgitsa88Stang
10-05-2015 07:33 AM
stangin1996gt
09-21-2015 11:01 AM
