Problem w/ Procharger Install
I'm almost done but absolutely can not get the piping from the blower to the intercooler to fit. Unfortunately ATI is closed until Tues so any help would be great. I have a rubber 90 extended metal 45 and rubber 45 left to connect to the double 45, just like the instructions. I've tried it a couple different ways and no luck. Either the length or the angles are way off. Love to get this done for the weekend.
Thanks,
Matt
Thanks,
Matt
I called ATI and they told me the fix in under a minute. The discharge nozzle for the blower was pointed too far up. Every Procharger owner should know, if they don't already, that the housing for the compressor including the nozzle can be rotated a full 360 degrees independent of the gear housing. The reason is the P1SC is used in a lot of different applications. Loosen the 7 allen head cap screws around the compressor and rotate. I needed to rotate mine 45 degrees down to get it to fit. Done.
ccdguy
Sep 19, 2015 05:20 PM
