What oil/filter do you use?
Old May 31, 2010 | 09:44 AM
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by Bigschwerm
Eneos 5w30 with a WIX filter..i change the filter out at 3000 miles and add a fresh quart until i hit 9000 miles then i do a full change.
Yep, his bearings are thanking him for that move...
Can you say 'combustion by-products cause acids
to form in the oil over time'?
Rosco P Coltrain 5W30 and a MO899 Mopar filter
Old May 31, 2010 | 11:03 AM
2005Redfire6's Avatar
2005Redfire6
Sorry what he does is no bueno? Sounds like it!
Old May 31, 2010 | 04:44 PM
Bigschwerm's Avatar
Bigschwerm
Eneos is a full true synthetic oil and can be easily run for 10,000 miles before a full change i just do the filter swap because i don't believe in high milelage filters.
Old Jun 17, 2010 | 10:22 PM
Twstones's Avatar
Twstones
I usually use the designated Motorcraft, Walmart stocks it. I know there's some debate for which filters are better, but 1st I guess this is good enough for Ford, and 2nd I always change both the oil AND the filter every 3000 miles. Put over a 100,000 miles on each of my last 5 cars, and never had an engine problem. Good maintenance pays off...PS I've always changed my own oil since I started driving, 49 years ago.
Old Jun 19, 2010 | 09:10 PM
Nice Pony's Avatar
Nice Pony
I use Amsoil 5W-30 full synthetic and Motorcraft FL820s
My 4.0 Mustang has 115,000 miles with 85,000 running an X-Charger supercharger along with plenty of open track, autocross and daily WOT accelerations.
Old Jun 24, 2010 | 01:38 AM
Unleashedbeast's Avatar
Unleashedbeast
can I make a suggestion and upgrade to the Amsoil SSO 0W-30? It's a much more robust oil. Some have even reported MPG gains.
Old Jun 24, 2010 | 10:42 AM
2005Redfire6
Wow you've been running 85,000 miles with the X-charger? Thats awesome makes me feel alot better about accelerating hard occasionally since I just passed 40,000. Also you do autocross.
2 weeks ago I switched from the Ford synthetic blend to Mobil 1 10w-30 and I'm using the Ford 820S Filter.
Old Jun 24, 2010 | 12:13 PM
Nuke's Avatar
Nuke
Using the Motorcraft blend and filter is excellent for 99% of drivers. Just be sure not to exceed 7500 miles. If you're doing a lot of stop and go and city driving, change it by 5,000 miles or so. You can't beat the price for the oil and filter at WallyWorld.
Old Jun 24, 2010 | 12:24 PM
157dB's Avatar
157dB
Cut & Paste Expert
Pure oil now, Puroilater
Old Jun 24, 2010 | 12:44 PM
2005Redfire6
I've never even seen or heard of that before until you mentioned it, where do you get it?
