New headers??
I was thinking of doing headers next(just did dual exhaust). fairly new to working on cars, so would it be wise to have someone install them for me or could I tackle it myself?? haven't decided on which to get get yet. either going w/ JBA or Pypes shortties. A little advice would be much appreciated..
Well, I put my JBA's on over the weekend. Install was straightforward. Only problem I had was tightening 2 bolts on the driver's side and one on the passenger's due to the curvature of the tubes. These required hand tightening and was a PIA but worth the blood and sweat.
Road test: I did notice an improvement in acceleration. To the point that I may have to eat my own words about exhaust mods on an N/A 4.0. If these headers made a noticeable improvement (and they did; judging by how far I laid tire at WOT compared to pre-headers), perhaps duals do also as many have stated?
Anyone with both headers and duals comment on seat-dyno gains? Did duals provide a similar seat-dyno improvement as the headers?
I was seriously looking at this from an aesthetic, sound, and weight standpoint, and was pleasantly surprised at the improved throttle and accel response!
BTW, I weighed the stock headers and they were ~ 10lbs each. The JBA's were ~ 5lbs each. So the JBA's are 1/2 the weight of the stock irons. Not bad for the tally
i went with some ebay stainless knock offs myself. 115.00 shipped. the pass side is the easy side. i jacked it up and removed the cat nuts and dropped the y pipe from below. everything else was from the top. pretty easy install really. i removed my wires and the cai, one bolt for the dipstick and it pulls up and out of the way. you will need a 1/4" longer bolt to re install the dip stick tube cause of the flange thickness( its metric too). its easier to just remove the egr tube, connect it at the header first, then connect it at the top by the tb. i re used the oem manifold studs too. you`ll have to bend the coil bracket just a little( tweek it) to go over the flange too, not a big deal. pretty straight forward, r&r.....you can tell by looking at them and measuring, they are gonna flow much better than the cast iron, and look a ton better too. i`m running a jba stainless h pipe kit and gt takeoffs. i do feel the exhaust made a nice gain in the seat of the pants test
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
