Cleaned BBK intake how long do i wait?
Old Aug 4, 2011 | 02:52 AM
IvanRad's Avatar
IvanRad
Default Cleaned BBK intake how long do i wait?
I just used a k&n cleaning kit on my BBk intake it rinsed perfectly and i made sure all the soap/solution came out. I have been letting it naturally dry on towels for about 6 hours when is the appropriate time to oil this thing? The instructions aren't very clear on how much oil you should use? any tips? thanks
Old Aug 4, 2011 | 07:27 AM
Nuke's Avatar
Nuke
I typically allow ANY of my oiled filters to dry for 24 hours unless I had it drying with moving air, in which case I gave them 12 hours.
For oiling, do you have a spray bottle? I find that about 2-3 light applications about 15 minutes apart inside and out works fine and hasn't caused any MAF contamination for me.
Old Aug 6, 2011 | 01:24 AM
IvanRad's Avatar
IvanRad
thanks nuke it worked perfectly. I cleaned it waited to days to naturally dry, then filled a tiny spray bottle with a little oil gave it a good all around spray and installed it this morning perfectly works. Thanks again
Old Aug 21, 2011 | 06:39 PM
amustangrocks's Avatar
amustangrocks
if you want to get precise with it, you can call s&b filters. they make filters for all the cai`s, give them your dimensions and they can tell you how many grams of oil to use. thats how i do mine. my jlt filters require 48 grams of oil. i use a digital kitchen scale to weigh them as i spray the oil. then i let that sit for a day or more.
when i wash it i let it dry a couple days
i also bought a 2nd filter so i can install a clean filter, and take my time cleaning the other. works out really well
http://www.sbfilters.com
jpplaw
Mar 19, 2025 08:53 AM
djbigskrilla
Sep 20, 2022 01:04 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
Calizic
Aug 28, 2015 01:46 PM
Figure8allday
Aug 22, 2015 11:11 AM
