Throttle Body
Old 03-26-2013, 05:50 PM
Nuke
Nuke's Avatar
The OE wires shouldn't need replacing; they'll likely outlast you owning the car. As far as plugs, that would depend on the mileage. My wife's 06 V6 has only 38k on it and the plugs aren't on the radar yet.
Nuke is offline
Old 03-28-2013, 06:22 AM
06RubyFire
06RubyFire's Avatar
Wow! 38K on an 06, I thought my mileage was low @ 44K on an 06, impressive.
06RubyFire is offline
Old 03-28-2013, 10:53 AM
Nuke
Nuke's Avatar
I bought her the '06 in '09 with only 9600 miles on it.
Nuke is offline
Old 01-02-2014, 01:43 AM
oristag
oristag's Avatar
>Nuke
Thanks for sharing your knowledge.
oristag is offline
Old 01-02-2014, 06:02 AM
VistaBlue09
VistaBlue09's Avatar
Originally Posted by JRichard
Besides the CAI and tune, what else can I do to help performance/throttle response?
Thanks!
Lower rear axle gears will help performance.
VistaBlue09 is offline
Old 01-09-2014, 07:05 PM
teetertotter
teetertotter's Avatar
Default TB Maintenance
My 06, 4.0L, has almost 130k miles. It has had nothing but Tier 1 gasoline. Should I worry about the throttle body being dirty and is there a spring or 2 attached to the TB that should be replaced for preventative maintenance? My engine has nothing but quick response. Should I be concerned with the TB for any preventative maintenance? Recommendations? I would have my local garage mechanic do the work, if is required. Thanks for any input.
teetertotter is offline
Old 01-10-2014, 08:23 PM
IvanRad
IvanRad's Avatar
clean your TB
flush your tranny
replace fuel filter
check your gaskets
tighten up bolts.
Check bushings
change that diff fluid
just buy stuff slowly every time your at the auto parts store
use a can of seafoam every 8000 miles
IvanRad is offline
Old 01-17-2014, 09:52 AM
157dB
Cut & Paste Expert
157dB's Avatar
Tier 1 gas is clean.
The PCV oil is what dirties up the TB over time.
Unless you have an aftermarket catch can in place...
157dB is offline
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
guitarman376
09-30-2015 05:54 PM
GLOCKer
09-28-2015 07:36 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: Throttle Body
