Bypassing the AC
Old Jan 2, 2018 | 02:29 AM
Simon Burfield's Avatar
Simon Burfield
Default Bypassing the AC
Hi all, I hope someone can help me.
I have a 2005 V6 4.0, which I love, when I brouight it the AC never worked (rad damaged). Not a issue in the UK as never really need it.
However, now the pump is **cked because I guess because no lube is going round. What I want to do is bypass it which does look possible.
Does anyone know the belt size to bypass the AC?
Old Jan 2, 2018 | 12:06 PM
Urambo Tauro's Avatar
Urambo Tauro
Welcome!
I can't answer the belt size question, but as long as the AC clutch remains disengaged, it's basically an idler pulley. No need to bypass it unless something's wrong with the pulley/bearing/shaft, or if you're trying to remove AC components to shed weight.
Old Jan 3, 2018 | 03:48 AM
Simon Burfield
Thanks for replying, see I thought the same however its sounding like a can of beans with nuts in it. We disconnected the AC lead so it should just spin
I am going to try and bypass it today with a 1795 belt
Old Jan 3, 2018 | 10:04 AM
Urambo Tauro
Ok good to know. That noise could be the clutch, but hopefully that belt will work out for you.
Old Feb 8, 2022 | 02:21 PM
Dartanion's Avatar
Dartanion
what diagram did you use?
mustangDon
Jul 24, 2005 12:54 AM
donovan
Jul 4, 2005 07:37 PM
WeVie
May 23, 2005 03:54 PM
87 hatch
Mar 31, 2005 04:47 AM
pacepony
Jan 17, 2005 01:30 AM
