Engine dies under full throttle
Old Aug 12, 2018 | 08:12 AM
polemides's Avatar
polemides
Well i cleaned the MAF and throttle body to no effect. So i just sat and thought about the problem for a while. Thinking about the electronic throttle, the car acts like when i hit full throttle its sending value outside the range of the throttle bodys array of known values. So it shuts down. I would think this would throw some sort of except code. Like and index out of bounds or something but all i get is the p0607.
any ways continuing on this train of thought i researched on calibrating the throttle to the throttle body. This forum is great as i found several threads on it, although with mixed responses as to whether it actually works. But i tried it cycled the throttle through it full range 3 times as suggested i started the car, turned off tcs and overdrive, stomped on the throttle and...... the car launched! A little tire squeel from the wet road but other than that flawless. I repeated this several times with no cut out so i think that was the issue .
thanks for providing me a sounding board to bounce my thoughts off from and providing suggestions. This is a great community and i hope i can contribute to it
sean
Old Aug 15, 2018 | 02:20 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Thanks for the feedback. Anecdotal evidence on the throttle pedal calibration procedure working to fix something...I think that's a first for that one?!
yodkelarc3
Sep 10, 2012 08:04 PM
h3kt1k
Mar 15, 2010 10:02 AM
07PonyVert
May 12, 2008 06:52 PM
Eleanor06
Feb 27, 2008 01:13 PM
95cobragirl
SVT Forums
Dec 30, 2003 02:25 PM
