2005 v6 throttle not working
Old Feb 7, 2023 | 02:35 PM
Docolds1966's Avatar
Docolds1966
Default 2005 v6 throttle not working
106k miles. owned since new. all of a sudden when driving the wrench symbol and check engine light popped on and the throttle acts like it is no longer connected. i cleaned the throttle body, changed the sensor in the air intake.hose and wiped the codes but same thing. idles perfectly but will not increase at all rpm when throttle is pushed?
Old Feb 7, 2023 | 03:03 PM
JimC's Avatar
Super Moderator
What are the codes?
Old Feb 7, 2023 | 06:46 PM
Docolds1966
Originally Posted by JimC
What are the codes?
p0108
Old Feb 15, 2023 | 07:35 PM
heyseeoh's Avatar
heyseeoh
Looks like that code points to the MAP sensor. However, a Google search that linked to another Mustang forum says it’s likely the EGR that needs to be replaced. Couldn’t hurt to clean the MAP as well if you haven’t yet. CRC makes a mass air flow sensor cleaner.
nickvagner68
Jun 28, 2022 12:26 AM
clemsondjm88
Oct 18, 2021 02:11 AM
VeeSixx
3.7L V6 Technical Discussions
Aug 8, 2020 07:14 AM
56TBird
Oct 11, 2011 01:37 PM
jebrewni
Dec 29, 2005 12:18 AM
