MAF screen?
MAF screen?
would removing the maf screen cause my car idle to jump around and last night it even died 1 time when i came to a stop....i had someone local tell me that this is the cause of the idle problem.....do i need to go to the ford stealership and get a new screen to put back in?....b/c i cannot stand my car dieing when it comes to stop!
RE: MAF screen?
i have been driving with mine out for about 8 months now and no problems at all, i took it out when i put my fipk on. Try taking your maf out and spraying the heater elements with some brake cleaner to clean them up, might help. it helped with a ruff idle on my car.
RE: MAF screen?
No problem on my '04, I clean my MAF's once a year with electrical contact cleaner, they will accumulate oil from a hi-flow filter such as a K&N. This is a cost of doing business with performance air filters. When installing an aftermarket CAI always be sure not to over-tighten the MAF to the pipe, this distorts the plastic housing causing the problem you describe. And when re-oiling your filter, allow it to sit overnight and let excess oil run off befor you install. Hope this helps,
John
John
jwog666
12-27-2021 08:09 PM
yourmom6990
09-14-2015 10:52 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
