thud going into 1st gear?
hey guys, for the past week i've been getting a thud from the tranny whenever i put it in first after coming to a stop sometime. it doesn't grind or anything, but the first time it happened i almost flipped because i thought someone bumped me from behind. please tell my trans isn't crapping out already [&o]
RE: thud going into 1st gear?
ORIGINAL: Brute03
I'd say just be mindful of it, and if it gets worse, you may be in the same situation I am.
i think the first owner used to beat my car too, the rear pads were almost worn to the metal. a broken mount was my first guess but then again it only does it when going into 1st gear
ORIGINAL: Brute03
The clunk to first is probably the most noticable because of the gear ratio... like I said for mine, it will clunk loud enough to hear for all gears except 5th. I haven't noticed if mine has been getting worse over time, but I've been paying attention to it for the past 5 months, which has only been 2000 miles.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
