Vibrations"
RE: Vibrations"
I am still fighting this problem right now... Is it RPM dependent??
I ended up changing my tranny mount (was toast), U-Joints (I don't know if they're any good) and now I'm in the process of swapping my Tranny (just not good)...
I hope to fix this w/ the end all be all....
Also, how's the rear end in your car?? Do you get any whirring, howling, or whining??
JT
JT
RE: Vibrations"
I have the same problem, but it is only within about a 200 HP range. My mechanic told me there is nothing that can be done because my aftermarket rims are not exactly round. I guess that is what happens when you get a good price. That could be the problem. If it only happens when you brake then it is probably a warped rotor. Need a few more details before we can know for sure but those are a few places to start looking.
RE: Vibrations"
Yeh, i do get some whining
ORIGINAL: GodAmGT00
JT
JT
RE: Vibrations"
Have you ever looked at your rear diff's inerds?? You may want to start there.. If you're not familiar w/ what good vs. bad is, take some pictures, and post them here..
Can you tell where the whining is coming from?? That's another good thing to listen for...
JT
JT
RE: Vibrations"
Thanks a lot i will check it out...
ORIGINAL: GodAmGT00
JT
JT
ccdguy
09-19-2015 05:20 PM
