Old Nov 20, 2015, 12:43 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Interior Guides
Print Wikipost
1996 power window help!
Old Mar 23, 2006 | 10:20 AM
krm486's Avatar
krm486
Default 1996 power window help!
Last night i noticed my passenger window wasn't sealed good. So i mess around with it and the d@mn window comes off the track. WTF!! Now i cant get it back on right. Is there any easy way to fix this or should i take it to the shop and not waste my time?
-It's a power window by the way.
Old Mar 26, 2006 | 08:45 AM
yoteehunter's Avatar
yoteehunter
Default RE: 1996 power window help!
Sometimes autozone and the likes sell power windo repair kits. You will have to pull the door panel to check it out. Many of the components in there are made of plastic and just flat out wear out over the years. The best thing to do is pull the panel to see what going on in there and then judge weather or not you can fix it. It is a PITA I can tell you that.
Old Mar 26, 2006 | 01:13 PM
monkeydude3's Avatar
monkeydude3
yep. Windows are a pain in the ****. I had to replace a window motor on my mom's infinity and I've had a handful of window problems at work. From simply a clip off inside to one full out broken off the mount. I'd say take the door panel off and see what's going on. If it appears you can't go much farther, i'd say leave the panel off and take it to a shop you trust.
Getting it back on the track is a pain, it will require the loosening of both the tracks so they are wobbly, and then get the window in between them and tighten them back up
logan409
Sep 26, 2015 07:43 PM
DreadPirateRoberts
Sep 26, 2015 02:11 PM
2poor4u2
Sep 26, 2015 11:08 AM
Sep 25, 2015 06:58 PM
lmurf60
Sep 24, 2015 10:07 PM
