fuel pump wiring
does any body know which of the four wires going thru the trunk is the hot wire for the fuel pump? i'm trying not to drop my tank. theres 2 black wires assuming those are ground that leaves a yellow and a brown with a purple stripe.
what are you trying to do? ill be able to tell you this weekend cause im dropping my tank again, but mine might be different because mines a 96gt. are you trying to wire in an inline fuel pump? or a cutoff switch?
its a 98 model dropping in a carbed 351 . since i don't have a computer any more i have to rewire it into the ignition . but i did figure it out i just followed the wire from the fuel reset switch, its the brown and purple.
ORIGINAL: mark54
jaiidutch
Sep 14, 2015 10:29 AM
