fog light help!
fog light help!
i need help with for lights, after washing my care both of my fog lights just went out, i checked all the fuses n they seem to all work, but i dont know wich one is the exact one for the for lights does any one have a map of the fuses i can have?? or ne idea wich one is it??? or wat could be the problem??
RE: fog light help!
This is a very common problem that has been answered several times in here. These fog lights aren't very water proof. If you pull out the plug in the back of the light and the bulb is busted....then you've got water in the fog light. Removed the whole fog light assembly (its only 3 screws) and filled it with water, if the water leaks out then you can kinda tell where its coming in at. Clean it really good and put a bead of clear silicone around all the cracks and seams. I did this about 4 months ago and haven't busted a bulb since.
RE: fog light help!
same thing happened to me although it didnt rain they were working fine and then i went in a store came out and they both blew out i just replaced them since then they have been good ( 5 months ago)
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
