OBD-II P0605
Old Apr 29, 2006 | 12:48 PM
micheal0484's Avatar
micheal0484
Default OBD-II P0605
P0605 Internal Control Module Read Only Memory (ROM) Error
I need to know what to do to fix this problem.
Old Apr 29, 2006 | 12:49 PM
Tac2cul's Avatar
Tac2cul
Default RE: OBD-II P0605
what year?
and do u have a chip installed?tell us what youve done to it so far
Old Apr 29, 2006 | 12:50 PM
micheal0484
98 GT
Old Apr 29, 2006 | 12:52 PM
Tac2cul's Avatar
Tac2cul
answer the rest please and we can start to help
also is the car even runnning tell us all the info you can
Old Apr 29, 2006 | 12:56 PM
micheal0484
Sorry I didnt see the rest... I have hypertech programming. I also have a few mods. CAI, UD pulleys, MSD Coil and Wires, TB Spacer, X pipe no cats, Upgraded clutch.. umm i cant think of anything eles right now.
Old Apr 29, 2006 | 12:58 PM
Tac2cul's Avatar
Tac2cul
well remove the hypertech if you can and put it back to stock settings and see if that helps.
What ive found so far is a P0605 constitues a PCM replacement so i would try removing the hypertech and going from there
Old Apr 29, 2006 | 01:01 PM
micheal0484
I figured that had something to do with it. I have a friend who owns a Rebuild shop and he used his very expensive computer to read it. The fan came on but then went right off and thats when it brought up that code just after that fan turned off. I can also change the CCRM because I got another one and it might be bad.
Old Apr 29, 2006 | 01:06 PM
Tac2cul's Avatar
Tac2cul
i would remove the hypertech and give it a shot....
if all is well after that reinstall da hypertech and see if it helps...sometimes chips hiccup
Old Apr 29, 2006 | 03:54 PM
rbstang's Avatar
rbstang
the hypersuck tuner gives out random codes when its installed. put it back to stock and rescan it. then get a diablo or sct
Old Apr 29, 2006 | 04:50 PM
jamie660's Avatar
jamie660
Lose the CrapperTech Tuner. It will actually make you lose power. Get a Diablo.
Urambo Tauro
Oct 5, 2015 09:37 PM
xxkazp3rxx
Aug 31, 2012 09:56 AM
07vbluestang
Mar 22, 2011 05:00 PM
07vbluestang
Mar 1, 2011 09:52 PM
xxkazp3rxx
Nov 7, 2006 11:31 PM
