O/R X install please help fast!
ok just got a o/r x-pipe and need to know if im sposed to have gaskets.... it bolts to the stock manifolds.... do i need new bolts and gaskets? also what should i ask for if i need them what size? plz hurry need to get this put on today its my only off day at work
RE: O/R X install please help fast!
resue the metal gasket on the driverside. It should have came with bolts. You will reuse the nuts that were takin off the headers. The only bolts that are needed are the ones that connect it to the catback. If it didn\'t come with those try to reuse the ones you have before buying new ones. Also FYI when I did mine the metal gasket did not come off the header. But check to see if it is in the h-pipe when you remove it. Also soak the header bolts with WD40 and let them sit for a bit. I did this and had all the header bolts off in about 15 mins.
