Slight Miss Below 2000 RPM
My '02 GT 5spd (70k miles) seems to be developing a slight hesitation or miss when below 2000 rpm and moderate throttle.
I can describe it as kind of a hiccup when accelerating below 2k.
It does it a little more often when just started, but continues until the coolant temp guage reads fully warmed up.
It doesn't seem like it should be that cold blooded, I mean it's bone stock....
Help me out guys! What could it be?
plugs, fuel filter, iac, something else?
Thanks
Vince
Thanks
Vince
RE: Slight Miss Below 2000 RPM
Ok, I just checked my IAC because I was going to try cleaning it out since it's free and.......
Isn't there supposed to be a spring in it? Or is it just open and the spring compressed? I pulled it off the plenum, turned it around and shined a flashlight in there and there is no spring!
Also, I thought the IAC was only supposed to work when the throttle is closed, my problem happens when I am at moderate throttle....
HELP!
Vince
HELP!
Vince
70,000 miles... wouldnt hurt to do a tune up anyway even if the car still missed after u did a tune up.
Spark Plugs
Fuel Filter
Clean/Replace Air Filter
Clean IAC which you already did...
Rotate tires unless you have huge tires in the back.
Change oil and oil filter.
SEA FOAM !!!
Spark Plugs
Fuel Filter
SEA FOAM !!!
Matt's 95 Stang
10-05-2015 07:16 AM
