all sorts of unexplainable problems...
alright well my 03 gt only has 50k on it and in the past month these things no longer work, cruise control, passenger side power mirror, my locks make a scratching noise when they are unlocked, driver side fog light, and ball joint is worn out.... i just dont understand why all of a sudden all of these things are going out could it be one central thing wrong with my electrical system or what? any input was be great
RE: all sorts of unexplainable problems...
I would say the ball-joint is unrelated to the other issues.
Do you frequently turn your wheels when you are not moving? That could be the issue with your ball-joint. I know sometimes it can't be avoided, but the less you do it, the better.
i would say check your fuses as well. I had a vw that would start to act up when it was the rainy season, fuse box was damp. Also, put a meter on your battery and check your charging system. I had an alt go start to go bad and things started failing as there wasnt a charge being stored. good luck.
SteelerNation82
09-09-2015 09:06 AM
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
