PROBLEM SOLVED WITH 01-04 TREMEC T3650 TRANNY 5 SPEED
Old 05-28-2006, 02:50 AM
mustang_01bullitt
mustang_01bullitt's Avatar
Default PROBLEM SOLVED WITH 01-04 TREMEC T3650 TRANNY 5 SPEED
IF YOU ALL WANT TO STOP HAVING PROBLEMS WITH THE T3650 5 SPEEDS THEN GET THIS PRODUCT IT WILL HELP A WHOLE LOT STEEDA{ CLUCH QUADRANT }EVERY ONE THINKS ITS THE TRANNY HAVEING PROBLEMS IN THE INTERNALS ITS NOT, ITS THE CLUTCH QUADRANT UNDER THE DASH ITS MADE OUT OF PLASTIC AND NO GOOD FOR POWERSHIFTING OR RACING IT JUST A PEICE OF **** THEY SHOULD OF MADE THEM OUT OF METAL BUT DIDENT ANY WAY GOOD THING STEEDA MAKES A GREAT CLUTCH QUADRANT READ THIS ABOUT THE STEEDA CLUCH QUADRANT AT THIS LINK
http://www.steeda.com/
THE FACTORY PLASTIC SELF-ADJUSTING QUADRANT IS FINE FOR STOCK CLUTCHES, BUT WHEN YOU ADD A HEAVY DUTY CLUTCH OR SOME FAST POWER ****S IT STARTS TO BEND THE FACTORY PLASTIC QUADRANT THISUN WANTED FLEX CAUSES INCONSISTENT CLUTCH ENGAGEMENT AND MISSED SHIFTS AT BEST, PLUS WEARS OUT YOUR SENCROS AND MAKES YOU BEND CLUTCH FORKS BECAUSE YOU TRY SO HARD TO PULL YOU SHIFTER IN GEAR IT MAKES IT OUT TO BE THE TRANNYS FAULT BUT ITS JUST THE QUADRANT I WOULD SUGGEST GETTING A NEW ONE IT HELPED MINE OUT A WHOLE LOT I SPENT ABOUT A LITTLE OVER 80 DOLLARS AND NOW MINE IS WORRIE FREE I ALSO HAVE THE STEEDA FIREWALL CABLE ADJUSTER CHECK IT OUT IT WILL HELP.
mustang_01bullitt is offline
Old 05-28-2006, 03:32 AM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Default RE: PROBLEM SOLVED WITH 01-04 TREMEC T3650 TRANNY 5 SPEED
This sounds like a sales pitch...and having only made 2 posts here, I have to assume it is one and you are going to be receiving a PM to clear all this up....
Locked
Dan04COBRA is offline
articman
06-21-2018 11:45 PM
musnicki
09-23-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
zanemoseley
09-06-2015 12:58 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: PROBLEM SOLVED WITH 01-04 TREMEC T3650 TRANNY 5 SPEED
