Tuner Questions
RE: Tuner Questions
Since were on Topic of Tuner Questions.... alright i have a superchips tuner. I am gettin ready to install my Off Road X pipe on soon. Will i have to Instal MIL eliminaters or Can my Superchips tuner Take care of it????
RE: Tuner Questions
RE: Tuner Questions
On the predator tuners, can u pogram things specifically, like, can i program in my current mods aon iwth my 3.73. gears and also my shot of nitrous. or do thye not work that way, do diablosport have to do it for me... cuzz that retarded 250 for a tune.
RE: Tuner Questions
This is everything you are able to do with a predator.. I have stock gears so I am not sure what a gear swat requires...
AVAILABLE PARAMETERS
Axle Ratio
Axle Ratio
Tire revs per mile
Traction
Idle RPM
Drive
Neutral
Cooling Fan
Fan high speed ECT 1 ON
Fan high speed ECT 2 ON
Fan high speed ECT OFF
Fan low speed ECT OFF
Fan low speed ECT ON
WOT Fuel
Fuel table 2k-4k
Fuel table 4k-7k
OBDII
EGR Switch
O2 Sensor Config.
OBDII MIL
OBDII Test
Heater bank 1 downstream
Heater bank 2 downstream
Rev & Speed Limits
Speed Limiter Off MPH
Speed Limiter On MPH
Rev Limit drive
Rev Limit neutral
Torque Modulation
Torque Mod. 1-2 Shift
Torque Mod. 2-3 Shift
Torque Mod. 3-4 Shift
RPM Shift Points
Shift Point rpm 1-2
Shift Point rpm 2-3
Shift Point rpm 3-4
Shift Pressure
Shift Firmness 1-2
Shift Firmness 2-3
Shift Firmness 3-4
Spark Advance
Spark advance 2k-4k
Spark advance 4k-7k
Tire Size
Tire Revs per Mile
Traction
Axle Ratio
Axle Ratio
Tire revs per mile
Traction
Idle RPM
Drive
Neutral
Cooling Fan
WOT Fuel
Fuel table 2k-4k
Fuel table 4k-7k
OBDII
EGR Switch
O2 Sensor Config.
OBDII MIL
OBDII Test
Rev & Speed Limits
Rev Limit drive
Rev Limit neutral
Torque Modulation
RPM Shift Points
Shift Point rpm 1-2
Shift Point rpm 2-3
Shift Point rpm 3-4
Shift Pressure
Shift Firmness 1-2
Shift Firmness 2-3
Shift Firmness 3-4
Spark Advance
Spark advance 2k-4k
Spark advance 4k-7k
Tire Size
Tire Revs per Mile
Traction
Luke9222
10-22-2015 11:55 PM
Daddys Girls GTs
09-14-2015 08:46 PM
ernesto-619
09-10-2015 01:32 AM
