p-51 intake vs bullitt intake
RE: p-51 intake vs bullitt intake
A P-51 or Typhoon will only benefit a built engine. A Bullitt intake will also not yield much HP. The stock one is fairly well desinged. Just pick up a Plenum and larger throttle body if you plan on going N/A or dont plan to build your engine.
it will work perfectly fine. I used my stock settings with a CAI, 75mm throttle body and accufab plenum with no problem. However when i did my X pipe and Catback in addition to these mods, my AF mixture was wayyyy off and i was putting only 223 to the rear wheels, I had a dyno tune done and now put dowm 250RWHP so eventually you may need adjustment
i believe its one or the other...............your best bet is a hand held programmer such as a SCT or Diablosport Predator. There are tons of different things that can be changed with these and it is needed to re calibrate your speedometer should you decide to get gears eventually
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
