clutch
05-06-2004, 10:05 PM
clutch
hey i just put on a brand new clutch in my car and for some reason the clutch pedal seems to vibrate when i leave it on gear. whats the problems? is the clutch bad?
05-06-2004, 10:07 PM
RE: clutch
what Type of clutch set up? and did the Flywheel need to be Turned? and could just be a minor Clutch cable adj..
05-06-2004, 11:08 PM
RE: clutch
Sometimes it takes around 300 miles for the clutch to blend in ...
Give it some time and it will hopefuly stop .. If not, then take it back
05-06-2004, 11:22 PM
I ♥ Acer
RE: clutch
Sometimes if you dont resuface the flywheel you might get shutter. Also you cable might not be adjusted properly. Might have too much slack.
05-07-2004, 12:47 PM
RE: clutch
A little oil left on the flywheel can cause the same problem. Should burn off after a while.
Thunderball
15
11-22-2015 11:49 PM
junior04
09-28-2015 10:53 AM
MacSerio
09-27-2015 01:05 PM
ccdguy
09-19-2015 05:20 PM
MasterLanMan
09-13-2015 08:21 PM
