GEARS
RE: GEARS
There should be a gear-sticky-post. Anyway, if you're worried about freeway driving then maybe even 3.73's may be too much for you. I do alot of freeway driving and roaring along at 3K for hours on end isn't my idea of fun.
Give the gear calculator on this forum a shot to see where your setup will end up running at...
RE: GEARS
ORIGINAL: 99gtstangThanks what kind of RPM range will you be at with 373 410 or 430 around 75-85..... now i am around 2300
It all comes down to what you can live with for mileage and revs at cruise speeds. If I drop my speed to 70mph I will drop to around 2650rpm's. That's OK with me. It's tough to get my convertible's 3300+lbs. going very quick with 281 NA cubic inches and automatic! I am hoping the exhaust, tuner and CAI all combine to keep the mileage close to what it is now. Anyone done a before and after with 4.10's? I am talking et's. I am thinking between 1 and 3 tenths better depending on supporting mods. Better mods, better reductions. mark
RE: GEARS
4.10s. if you get 3.73s you'll think even that's too much gear at first, then later you'll be wishing you went with 4.10s. trust me.... i listened to the whole "highway driving get 3.73s OMFG!!!11!1" from this forum. i'm just at 2000rpm at 65mph. 75 i'm at maybe 2200 or so. don't make the same mistake i did. i also have a blower and a stick.
RE: GEARS
ORIGINAL: 40thgtfl
i dont see how you could stand 4.10s you can only race to 111mph.... good luck against a srt4.
RE: GEARS
Why would you be held to 111MPH? Are you saying a stick car with 4.10's will max 5th at 111MPH? Can't be! How is the guy with the 3.73's turning 2500 or so at 75MPH, he could then hit 150mph at 5000rpm's! Please explain? I got my Motive gears and Predator tuner today. I cannot understand these predator instructions for anything!
Anyways my gears are going in next tuesday and even though I have an automatic which probably has a different amount of reduction in OD than a stick I think I will be fine, 2850 @ 75mph. Double the 2850 and get 5700 so I could if the motor made enough power hit 150MPH also. I need to go search for some simple directions for this predator! mark
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
