One question, One problem
Old 07-20-2006, 04:06 AM
Fryguy22
Fryguy22's Avatar
Default One question, One problem
First off I have a question to anyone who owns an Optima yellow top battery. I purchased one today since mine wad dieing and was wondering how you got the battery to lock-in to the compartment. The optima is skinnier then a stock battery so the clamp doesn't secure it. It's still fairly snug in there but not as tight as it should be.
Next I have a problem. On my way home tonight my car died in the middle of the road. I was cruising along and all of a sudden the power went out. It's not a problem with the new battery (headlights, power locks, starter, all still work). What could be wrong. Does it seem like the alternator?
Fryguy22 is offline
Old 07-20-2006, 04:18 AM
fiad06
fiad06's Avatar
Default RE: One question, One problem
mybe battrey conection went loose or something..
fiad06 is offline
Old 07-20-2006, 04:19 AM
Fryguy22
Fryguy22's Avatar
no like I said, the battery works fine. if the battery was dead the headlights wouldn't work.
Fryguy22 is offline
Old 07-20-2006, 04:22 AM
fiad06
fiad06's Avatar
alternator, test it out tommorow at autozone or something...
fiad06 is offline
Old 07-20-2006, 04:23 AM
MustangChris04
MustangChris04's Avatar
that happend to me once, everything was on but the engine lost power. I still dont know what did it. Maybe some shyt in the gas...
MustangChris04 is offline
Old 07-20-2006, 01:43 PM
Fryguy22
Fryguy22's Avatar
just got my car towed to the shop. I'll let you guys know what the problem was. I'm almost positive it was the alternator. Would my new battery have anything to do with causing the alternator to go bad, or is it just a coincedence that it went bad the day I put in the new battery.
Fryguy22 is offline
Old 07-20-2006, 01:50 PM
Blck98GT
I ♥ Acer
Blck98GT's Avatar
Probably just something went crap at a bad time... probably alternator.. A connection could be just a little loose though and you didnt know it and youre headlights still worked fine.. mine has done that before..
Blck98GT is offline
Old 07-20-2006, 01:56 PM
bsteen81
bsteen81's Avatar
The same exact thing happened to me when I bought the Optima. It crapped the alternator out on me that afternoon. Everything worked fine up until the battery was installed and from then on I had problems with power. Once I replaced the alternator everything worked fine.
bsteen81 is offline
Old 07-20-2006, 02:07 PM
Fryguy22
Fryguy22's Avatar
thats weird. Is the optima somehow too powerful for the stock alternator or does that make no sense at all.
Fryguy22 is offline
musnicki
09-23-2015 07:11 AM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 04:12 PM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
Quick Reply: One question, One problem
