clutch chatter
clutch chatter
whats the main cause of that??? rear main leak??? i can hear it at idle going up a slight hill... also through every gear you can feel it...... 3k miles on new king cobra clutch ...
RE: clutch chatter
Clutch chatter is usually caused by bad pressure plate fingers or springs, or contaminants on the disc/flywheel. Have you adjusted your clutch recently? With the car in nuetral, push the clutch to the floor, let it come up then put your foot under the pedal and pull it towards you. Do this a couple of times.
A rear Main leak will not usually get oil on the surfaces unless it's squirting out which again, is not typical.
RE: clutch chatter
an inch of play on a 99?? mmm...that's probably your problem there. The 99-00 have a weird clutch. At least in stock form they do. They do not require you to press the clutch pedal all the way to the floor to disengage. More like half-way. If you have an inch of free play I would adjust that out first then see how the clutch responds.
RE: clutch chatter
no i have a king cobra clutch and a manual adjusting cable only under the dust cover on the tranny but if i tighten it all the way i will problaby have pressure on the TOB the whole time and burn the bearings.....
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
