Do you need to buy heads before cams?
RE: Do you need to buy heads before cams?
ORIGINAL: joeybutts
If i am planning on getting a blower should i buy the bblower cams with the heads?
ORIGINAL: droptoppony
yes definately...they will work fine NA until you get your blower. Some guys actually run Crower St2 blower cams in their NA setup because they work so good.
ORIGINAL: joeybutts
do the cams first, seeing as you already have PI heads, all the head/cam packages you see use PI heads. you really dont need to do any headwork if you just want to make good street power. do cams/springs, exhaust gears and a blower, and you can have a nice 380-420 hp street car on pump gas with 10-12 psi. if you want to make more than 400 hp, you'll need a whole new shortblock to start, (i wouldnt push a stock block over 500 without any aftermarket work anyways) and you can port your heads then. but if you plan to go blower, but dont want to spend insane money, you can make the maximum safe hp on your stock motor without porting your heads.
uberstang1
09-20-2015 06:42 PM
Daddys Girls GTs
09-14-2015 08:46 PM
