mods
RE: mods
PI swap is swapping the cylinder heads on a '96-'98 for the performance improved(PI) heads on the newer model '99-'04 engines. The heads on the early 4.6 engines were fairly restrictive from the factory. In 99 Ford reworked them so they flow much better and named them PI heads.
I dont know what all is needed for the swap, just that a lot of people on here have posted about it and were very pleased with the results.
RE: mods
The pi swap is changing your head and intake manifold to the performance improved used on the 99-04 gt, 01+ Vic, and other v8 ford products. I'm not sure if you can find good write ups about it here but tccoa.com has a lot of info of this. If you do the pi swap be sure to get a manifold with the aluminum coolant crossover as well. You should also try doing a search on it.
RE: mods
Read this for a bunch of ideas: https://mustangforums.com/m_1091651/tm.htm
You could get under drive pulleys and an aluminum driveshaft. If you do the Pi Swap you shouldn't supercharge it w/o a special gasket or better yet get forged internals. Not much to make it scream w/o your heads being worked over really well and supercharged. Nitrous you can not have running all the time, but that would work.
RE: mods
what would add more power and be cheaper taking what heads you have already and getting them p and p or buying PI and doing the swap, i mean wouldnt be cheaper just to take the heads you have and have them worked?
