PI Heads
Old Aug 4, 2006 | 07:30 PM
Sebski's Avatar
Sebski
Default PI Heads
Where can i find PI heads for My 98gt, how much will they cost (most reasonable price prefered) , and do they come P&P'ed
thanks
Old Aug 4, 2006 | 08:01 PM
Sebski's Avatar
Sebski
Default RE: PI Heads
Old Aug 4, 2006 | 09:27 PM
04BlueGT's Avatar
04BlueGT
PI heads can be found on ebay or thru various on line stores. If you want P&P PI heads, look into Patriot or VT heads. Stage 2 Patriots can be had for $1300ish, but no cams.
Old Aug 5, 2006 | 03:23 PM
Sebski's Avatar
Sebski
Another question, are the PI swap kits that they have on Ebay any good, or do i stay away from those, there for around $1350 and come with heads, cams, intake mani, and a few other parts needed... are they any good.
thanks
Old Aug 5, 2006 | 03:26 PM
01BlueCobraVert's Avatar
01BlueCobraVert
Yes those kits are fine. You can get everything cheaper if you shop around and take your time getting all the necessary parts.
Old Aug 5, 2006 | 04:34 PM
lizzyfan's Avatar
lizzyfan
Underboss
ORIGINAL: 97mustangt
+1
Old Aug 5, 2006 | 08:14 PM
Sebski's Avatar
Sebski
thkans guys, if you dont mind can you recommend some places to start looking, cuzz its a wide wide world out there
thanks
seb
Old Aug 5, 2006 | 08:18 PM
Aixtreme89's Avatar
Aixtreme89
Just out of curiousity. I am going to build a new motor and wont need my SOHC motor that I have now, later. What would you buy a set of PI heads with comp cams valve springs and comp cams stage 1 cams, PI intake with accufab upper plenum, 75mm throttle body, MAC straight shot CAI w/ 85mm MAF. And mabye some LT headers with that?
Old Aug 5, 2006 | 09:04 PM
Sebski's Avatar
Sebski
truthfully i wouldnt even know wehre to begin pricing, but just maybe at the end of the summer if u put in a good quote... also since uve already done this install how much is it usually for a PI install, with the cams and what not?
thanks
Old Aug 5, 2006 | 09:24 PM
Aixtreme89's Avatar
Aixtreme89
ORIGINAL: Sebski
thanks
For the install I did it myself.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
Drastang
Sep 30, 2015 03:48 AM
