springs are lower on one side?
I just installed the pro kit and I have heard of some people say that there car is lower on one side . I installed them the right way. The question I have is will anything wear out faster or be a problem with the car slightly lower on one side?
RE: springs are lower on one side?
Why would your car be lower on one side? If all springs are installed properly and measured before install, car should be the same. The only possiblility is that the springs must settle before determining the measurement is correct. If car is still not level or the same, the springs are defective and must be replaced. Handling will be effected by uneven weight distribution. I would post a question to Stangsuspensions regarding your problem.
09-01-2015 08:16 PM
