steering wheel slop
Old Aug 30, 2006 | 03:18 AM
Zephid's Avatar
Zephid
Default steering wheel slop
it seems that my steering wheel is a little sloppy.. i was jsut wondering what i could do to make it tighter.
Old Aug 30, 2006 | 03:32 AM
monkeydude3's Avatar
monkeydude3
Default RE: steering wheel slop
ummm have a look at your tie rod ends, they may be a bit loose. Other than that, it could be in the steering shaft or the rack/pinion itself
Old Aug 30, 2006 | 03:35 AM
Zephid's Avatar
Zephid
how would i even go about getting to that... is that something i can do with out too much advanced car knowledge?
Old Aug 30, 2006 | 05:52 AM
FDNYBullitt's Avatar
FDNYBullitt
You can also check the swivel joint on the steering column shaft, just look between the inner fender well and the motor at the shaft and you'll see it. I've had to replace more then a few of those in the past as they get worn and sloppy. Plus check what monkey stated, thats also a slop area. Lift the car, lock the wheel and then try to move the wheels from outside all the time watching the front end parts for play, hope this helps, good luck.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
