shift stops on pro 5.0 shifter
RE: shift stops on pro 5.0 shifter
http://mustangworld.com/ourpics/fcar/shift2.htm check this link out everything you need to know gap the stops at .10 for the record but detail is explained in the write up
i dont know about pro5.0 shifters...but on the 3650 for my MGW it said not to use the shfift stops. i dont know if that write up is for older/other trannys or if the pro5.0 is different. just thought id let ya know.
Your welcome kcp1989
It is for all pro 5.0's and I would assume any other shifter with stops on a GT What advantage would you have to not using the shift stops? Just curious......
ORIGINAL: Car_Ramrod
in the instructions for the MGW it said something about how the 3650 transmission has internal shift stops in the transmission or something like that...so you dont need to use the supplied shift stops.
...at least i hope i read that part right lol.
