What type of oil should I use?
RE: What type of oil should I use?
I used 5w-30 synthetic over the summer but I'm about to be supercharged, what should I use?
I use ChemTech synthetic (boost blend - more zinc and other crap I guess). In tests it blows away Royal Purple and Mobil 1. I currently get it through a local shop (Evans Racing) and don't know where else it is available. I'm trying to find website info but I think it may be wholsesale only currently. It's supposed to be a really good oil.
They just did a dyno comparison with a local motorcycle shop's drag bike ('Busa). They ran a baseline test, changed the oil using their synthetic motorcycle blend and gained 3 whp. That's right, 3 hp at the wheel from an oil change. This is considering that nothing changed except the oil and the two pulls were minutes apart.
ORIGINAL: straitwangin
if you dont have thousands in upgrades you dont need to get synethic oil. regual oil i recommend penzoil is fine.
With synthetics today, it's down right stupid to not use them, even on a stock car!
You do realize that a heavily modified engine will run more efficiently and actually produce less wear & tear on the internals (up to a certain HP amount)? A stock engine can actually need more oil protection for casual driving.
mrappe
09-26-2015 10:16 AM
