The Powerband
Old Sep 15, 2006 | 12:50 AM
bumpinwheels95's Avatar
bumpinwheels95
Default RE: The Powerband
for the record i looked up what it says for the powerband
they said stock 215hp@ 4500 rpm
280ft-lbs (trq) @3250 rpms
should i really shift that low?
Old Sep 15, 2006 | 01:04 AM
hotrod7687's Avatar
hotrod7687
ORIGINAL: 72MachOne99GT
i do want to clear something up..
you cant just 'change' the redline of a vehicle can you?? unless youve done some work??
and as far as shifting/launchign..
if youre able to play around witha launch, you'll probalby find 3500-4K or so is gonna be a nice spot to feather the clutch out from
and for shifting.. go half way between max tq and redline (though, that would require dyno-ing)
I believe the redline is set at the max rpm that it is safe to spin the rotating assembly without damaging it. You can add things that will help the car make power higher in the rpm band, but the stock crank, pistons, rods, etc. are not supposed to spin past the redline because you could damage something. You would need forged crank and rods, balanced rotating assembly, and the valvetrain to match to be able to safely increase redline of the engine.
Old Sep 15, 2006 | 01:33 AM
72MachOne99GT's Avatar
72MachOne99GT
2010 Blue Ball Award Recipient
ya, thats what i thought..
i almost wonder if he is confusing 'rev-limiter' with redline
Old Sep 15, 2006 | 01:38 AM
St4ng07's Avatar
St4ng07
I usually shift about 5200-5500. Does pretty good. Chirps them into 2nd everytime.
Old Sep 15, 2006 | 01:56 AM
handyandy's Avatar
handyandy
anyone know the good range of rpms for a PI stang such as my 01?
Old Sep 15, 2006 | 01:59 AM
JPGT_00's Avatar
JPGT_00
go get your car dyno'd and see where your power drops out, cars are going to be different, i think mine was around 5500, as far as changing your red line, with a tuner, i dont think you can, but you can turn your rev limiter off.
bumpinwheels95
Sep 28, 2006 03:50 PM
bumpinwheels95
Sep 27, 2006 05:45 PM
88 rubber eater
Jul 6, 2006 08:23 PM
88 rubber eater
Jul 6, 2006 09:47 AM
MyStangCobra01
31
May 1, 2006 09:00 PM
