Mac Prochamber Sleeve?
Old Oct 3, 2006 | 11:54 AM
meechuacon's Avatar
meechuacon
Default RE: Mac Prochamber Sleeve?
Anyone??
Old Oct 3, 2006 | 12:37 PM
Jiggy_One's Avatar
Jiggy_One
No, the one side of the cobras headers are a tad bit shorter than the GT on the ball/socket side. This is what the guys from mac told me. You can use it if you want on your GT, but one side of your catback will stick out a little bit more than the other side.
Old Oct 3, 2006 | 01:13 PM
meechuacon's Avatar
meechuacon
Thanks Jiggy_One, I'm going to take a look tonight after I get off of work and see if I have any leaks. I'm not really sure, but it sounds like there might be a little leak on the drivers side manifold. If I do have a leak, I'm going to try putting that sleeve in and see what happens. I used RTV on all the connections so maybe it's just the way the prochamber sounds. Anyone have an easy way to see if there are leaks, I was thinking about putting some dish soap on the connections, kind of like checking gas lines for leaks. But maybe that's a bad idea. Any suggestions?
Old Oct 4, 2006 | 01:30 AM
eventer289's Avatar
eventer289
ORIGINAL: meechuacon
You'd have to make sure the pipes are cool, otherwise the solution will just burn off. That is what I did when I checked my cat back for leaks.
2007CalSpec
Dec 13, 2020 11:42 AM
baddog671
Jul 26, 2016 01:20 PM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
bconboy
Sep 24, 2015 01:55 PM
bconboy
Sep 21, 2015 12:52 PM
