friend converted his v6 into a cobra
Old Oct 24, 2006 | 01:23 AM
  #21
bluepony4.6's Avatar
bluepony4.6
Default RE: friend converted his v6 into a cobra
If your friend wants to swap in an engine from a M1 Abrams tank and has the money, patience, and means to do it I say go for it.
Yes there is a lot of money involved in swapping engines. However, there is a lot of misinformation being given out on this site from people with no experience in this area. A K member swap is not necessary. The 4.6 and the 3.8 use the same k member. You do not need to change out the steering column. The springs and struts/shocks do need to be changed. There is quite a bit of wiring that needs to be changed but from what I read it sounds like he's got a donor car anyway. In this case he's pretty much got everything he needs unless it was damaged too bad from the crash.
Old Oct 24, 2006 | 01:35 AM
  #22
Knight Mare's Avatar
Knight Mare
ORIGINAL: bluepony4.6
What he said^^^. Granted I only swapped in a 2v, but my 7.5 rear end is holding up just fine also. The only reason I didnt do it with a 4v was that I got the 2v for just over 1,000$, and the cheapest 4v was at least 2 1/2 times the price. It will NOT be magically more difficult to swap a 4v in there as opposed to a 2v. If your friend has a donor car, go for it. You'll learn a lot.
Old Oct 24, 2006 | 11:37 AM
  #23
GodAmGT00's Avatar
GodAmGT00
I personally don't like the 7.5".. I've had some experience w/ it, and it didn't hold for sh-t...
Maybe that's just my personal experience...
9" FTW..
JT
ctgreddy
Oct 14, 2015 09:05 PM
1996cobraconvertible
Sep 25, 2015 03:46 PM
BigWave916
Wheels & Tires
Sep 2, 2015 08:26 AM
Sidewayz6.0
Jan 30, 2004 02:18 PM
