rattling noise
Old 11-11-2006, 08:46 PM
neocon
neocon's Avatar
Default rattling noise
i have an 01 Gt and whenever i have my car in 5th gear on the freeway ill be cruisin around 2200 rpms and i push the pedal down further to accelerate i get a rattling noise underneath the car it is hard to explain but the sound is in between a rattle and a grinding noise. has anyone else had this problem or do you have any idea what it could be. thanks
neocon is offline
Old 11-11-2006, 09:09 PM
Shelbyville
Shelbyville's Avatar
Default RE: rattling noise
Do you have a Steeda shifter?
Shelbyville is offline
Old 11-12-2006, 01:26 AM
tstang2000
tstang2000's Avatar
mine does something like then but only when i accelerate and the rpms are around 4-5500k sounds almost like a grinding/really bad gear spin noise. and when im at idel, dont know if its the shifter/clutch but it ratles alittle. Have no idea what it is. Any 1 have any ideas??
tstang2000 is offline
Old 11-12-2006, 04:12 AM
neocon
neocon's Avatar
no i have a stock shifter but it is incredibly annoying. and when i hear it i feel like im breaking something on my car. anyone else have any ideas
neocon is offline
Old 11-12-2006, 04:58 AM
rbstang
rbstang's Avatar
things that help US out.
Car year
Mods
Miles
if its rattling it could be exhaust somethings loose and its rattling. i cant help you with out knowing the year and mods.
rbstang is offline
Old 11-12-2006, 10:30 AM
203Mach1ne
203Mach1ne's Avatar
ahh why do you ask if its a Steeda shifter????
I have that same problem--sounds like a rattling/vibrating noise when I hit the gas in any gear between 2-3K RPM
My car-- 2003 Mach 1 w/ Steeda shifter and SLP LM1 catback
203Mach1ne is offline
Old 11-12-2006, 12:29 PM
gsxrstang69
gsxrstang69's Avatar
When you hear this noise again quickly push in the E-Brake button. My button rattles somehow usually whne im cruising in 5th and go to accelerate. its annoying as hell. All I do is push the button in a couple times and it stops.
gsxrstang69 is offline
Old 11-12-2006, 10:54 PM
Shelbyville
My Steeda makes a lot of noise only in 5th and only when I accelerate. After the car warms up, the noise goes away. Weird. I wrote to Steeda. Below is their response. When it makes noise, it sounds like someone dropping a handful of BB's a little at a time into a empty coffee can.
Mike, as our Steeda Tri-Ax Shifters are drastically more solid, more positive and use no rubber or plastic components, internal transmission gear noise that is always present even in a new trans. will be amplified and transmitted through the shifter. This seems to quiet down after warming up as fluids are flowing better and the internals expand to take up cold clearances. The reason for the 5th gear only condition is that in 5th there is less load applied to the 5th/reverse cluster and as you tip in & out of throttle as small as an operation as it is, will cause a slack in that assembly and therefore noise! It is not a concern more so than an annoyance. We do have a Shift Isolator Kit # 555-7096 @ $7.95 that will lessen these effects if need be. Let me know if we can be of further help. This information will also tell you how smart the Ford Dealer Tech's are!!!
I invested in the isolator kit. Still hear it....
Old 11-13-2006, 05:04 AM
neocon
neocon's Avatar
ok i have an 01 mustang with cat back flows, CAI and sct xcal2 with 62,000 miles... i had a friend tell me he had a similar noise on his car that a shop told him was something in his catalytic converter that was rattling around i dont know though
neocon is offline
Old 11-13-2006, 01:18 PM
98MustangSTL
98MustangSTL's Avatar
It can't be the cats because it happens to me, and I don't have any.
98MustangSTL is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
KingRando
10-02-2015 08:06 AM
69Volunteer
09-30-2015 10:39 AM
UrS4
09-30-2015 10:13 AM
Ghost_Conscience
09-23-2015 02:17 PM
Quick Reply: rattling noise
