exhaust install
exhaust install
alright to start off my friend has a 99 stang gt 5 speed....this weekend his exhaust should be in which is a bbk offroad x-pipe and he got the slp loud mouth cat back and mil eliminators....im wondering how everything will go togather are x pipes hard to install? and the mil eliminators? how are they supposed to be installed? and how will all this sound? thanks guys
RE: exhaust install
Installing everything is the easy part. sort of
Pb blaster is a must with a long breaker bar to get those stubborn manifold bolts off.
Before installing everything, you might as well remove all 4 manifold studs because they are usually all messed up anyway and on the driver side, The threads stop early so you cant tighten it down all the way. I used those easyout threaded sockets they sell at autozone for 20 bucks. Then returned them of cource. But once you get all that out, I believe the stock cat back must be cut to get out.
Make sure you have the gasket for the passenger side manifold when installing the new x pipe.
The mills just go in between where the rear o2 sensors connect. pretty simple. make sure they want drag
Other then that, it might be a breeze and take 3 hours or it might take 20 hours like it did for me.
RE: exhaust install
hardest part is the damned passenger side, i'd try and get access to a lift.. working under a jackstand took me 3-4 hours to install the x pipe.. the catback was like a 15 min bolt up lols
RE: exhaust install
i actually just took off my h-pipe in 10 minutes here.. it's simple..
1/2 inch wrench
12" extender + 6" extender to make it easy
swivel
18mm deep/mid socket.
22mm wrench
jack it up a good foot or so, its all easy to get off, until you get to the 1 bolt on the passenger side, theres one o2 sensor in the way... i ended up using the box end on a 22mm wrench going over the wire and losening it.. then twisting the sensor wire so it unscrews itself.... faster than slowly moving in 2 inches of wrench space...
if it's ur first time, almost guaranteed those nuts will be on there GOOOOD.. remember - your feet are like 5x stronger than your arms, use your feet!
then theres 4 bolts where the catback connects.. I think I used 14mm.. then theres only 2 rubber hangers in the middle of the h-pipe holding it up.
disconnect those, kick the catback back alittle and jiggle that sucker down
1/2 inch wrench
swivel
22mm wrench
kawiguy827
09-01-2015 07:09 PM
