Gauges?
Old Nov 24, 2006 | 12:17 PM
red99gt's Avatar
red99gt
Default Gauges?
When starting my car up my guages are going all the way to the max and then coming back and reseting to its proper place. Why is it doing this? Its only doing it sometimes now but it wasn't doing it before. Is there something wrong?
Old Nov 24, 2006 | 12:28 PM
ackuric's Avatar
ackuric
Default RE: Gauges?
you're battery is shorting your ecu, resetting it everytime right as she cranks. replace the battery to fix.
Old Nov 24, 2006 | 12:32 PM
red99gt's Avatar
red99gt
Default RE: Gauges?
Resetting it everytime it cranks? So if I had my programmer on it would it reset that off and just be a stock tune?
Old Nov 24, 2006 | 01:46 PM
JPGT_00's Avatar
JPGT_00
Default RE: Gauges?
make sure you battery terminals are tight
Old Nov 24, 2006 | 01:49 PM
2VNA's Avatar
2VNA
Default RE: Gauges?
that is a problem that you want to get fixed. if it is shorting you could be right in the center of a hard corner and bam, everyting go's out.
Old Nov 24, 2006 | 03:35 PM
red99gt's Avatar
red99gt
Default RE: Gauges?
ORIGINAL: JPGT_00
They are definitley tight. The ones on it when I got the car were all corroded so I got some gold plated terminals and put them on. They are extremely tight so we had to smash them down with a hammer to cover the battery properly. No damage done, I assume the battery is just going, cause it just now started and there would be no reason for a short.
Old Nov 24, 2006 | 03:37 PM
wes ley n the G T's Avatar
wes ley n the G T
Default RE: Gauges?
Yeh check the terminals made sure they are installed correctly onto the cables and battery. Replace your battery if it continues.
Old Nov 24, 2006 | 03:43 PM
red99gt's Avatar
red99gt
Default RE: Gauges?
ORIGINAL: wes ley n the G T
Ok thanks. But would my programmer be gone if it resets the ecu or is it stored some how?
Old Nov 24, 2006 | 04:05 PM
bleau's Avatar
bleau
Default RE: Gauges?
I thought The gages and warning lights did a self test when you started the car?
Look in your owners manual.
jwog666
Dec 27, 2021 08:09 PM
andrew1969
16
Jan 8, 2016 02:48 PM
SteelerNation82
Sep 16, 2015 07:11 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
