11-12 second ALL motor stang possible? (4.6 or 5.0)
RE: 11-12 second ALL motor stang possible? (4.6 or 5.0)
ORIGINAL: 04ShakinSteed
Here is my 12 second stang:
Mach 1
Steeda Tri-Axe
BBK Longtubes, O/R X pipe
C&L MAF
no engine work needed!
Mach 1
Steeda Tri-Axe
C&L MAF
Jay
you no what is sad is i have maybe 1200 bucks in my car and its a 12 sec mustang, and what is worse with my mph im faster then JayC. Currently with 15 inch stock tires i ran 13.4 @ 107.43 MPH. Matter of fact the heads i have are iron head GT40P truck headsand can be considerd stock type.So with some tires it should easily run 12.6 or 12.7 ! So if you want a fast car for cheap and daily driver dude go 5.0 . Sorry 4.6 guys!! Also a Mach 1 can run 12s with exhaust and tires. Even though the one i have seen is a auto and he runs 13.8s @ 102 !
ORIGINAL: RJM02GTDrag
Jay, ya got long tubes on that bad boy?
ORIGINAL: JayC
Here's my cars 12 second mods......driven every day
Engine:
Apten Performance Tune (SCT Flasher)
Steeda Pullies
K&N w/ no airbox and right headlight pulled at track
Denscharger MAF to TB only
MAC o/r x-pipe
Welded in Flowmaster 40's mufflers
Drivetrain:
FRPP 4.10's
UPR shifter
King Cobra clutch
Axle tubes welded
FRPP 31 spline T-Lock
Moser Axles
Suspension:
Fox-body 4cyl springs (cut) up front w/ Lakewood 90/10 struts
Fox-body V8 springs (cut) w/ Monroe Sensi-tracs out back
Airbag in RR spring
No front swaybar
UPR sub-frame connectors
Steeda 4600 Lower Control Arms
Torque boxes welded
No quad shocks
Wheels/tires
Front - 165x15 Pep Boys on 15x4 Telstars
Rear - 275x50x15 BFG DR's on 15x8.5 AutoDrags
Launch @ 5000 and power-shift @ 6000
Jay
Engine:
Steeda Pullies
MAC o/r x-pipe
Drivetrain:
FRPP 4.10's
UPR shifter
King Cobra clutch
Axle tubes welded
Moser Axles
Suspension:
Airbag in RR spring
No front swaybar
Torque boxes welded
No quad shocks
Wheels/tires
Jay
Jay
Did you run it on the spray yet?
Jay
ORIGINAL: Stinger
Jay
This is entirely possible provided you run slicks at the strip not street tires. Don't go above 3.73 rear gears with an auto or 4.10's with a stick and make sure you have a good postion traction rear end in the car. Some rear suspension work with new upper and lower control arms will help you get down into the 12's with a decent engine. You also need to loose some dead weight out of the car too, there's lots of stuff you don't really need that can be removed and still have a daily driver. There are too many engine combinations that can do this to discuss them all here. Let's just say a good cam with some heads and intake/throttle body improvements will get you there.
