Old Oct 23, 2015, 04:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
Print Wikipost
Reset computer?
Old Dec 30, 2006 | 09:05 PM
Shelbyville's Avatar
Shelbyville
Default Reset computer?
I just bought a MAC CAI for my 2002 GT which I have owned for about 2 months now. There have been no mods to the engine that I can see, however the previous owner did replace the stock exhaust system. My question is will the computer freak out with, what I hope to be, increased air flow after installing the MAC or will I be OK. It should adjust itself for the difference in air flow, shouldn't it? I have read, both on this forum, and other places that disconnecting the battery for 20+ minutes will reset the computer but I am wary about doing that unless I really need to.
Old Dec 30, 2006 | 09:07 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: Reset computer?
It wil be fine, no need to reset.
Old Dec 30, 2006 | 10:18 PM
AJ06GT's Avatar
AJ06GT
As code said, there isn't enough difference in just changing the intake to need to reset the computer, however it's really not a big deal. You probably wont even notice you reset it (other than the clock being wrong haha). If you really get on your car, you might notice it being a little off, but I can never tell when I reset my computer, I did it twice today too.
Old Dec 30, 2006 | 11:02 PM
Shelbyville
Good to know. Thanks. Who knows, it might make it better if I did. Maybe someone tried to tune it and screwed it up.
Old Dec 31, 2006 | 06:24 AM
kylebgt's Avatar
kylebgt
umm when you are doing any kind of work under the hood you need to unhook the battery. Which in turn resets the ecu aka "computer" After the ecu is reseted it will change the air/fuel accordingly. It would do this without a reset but would do it more efficiently with one.
Old Jan 2, 2007 | 01:59 PM
Shelbyville
Thanks. I typically do unhook the batter depending on what I am doing. It has to be unhooked for 20 minutes supposedly to reset the ecu. For something like this, it "should" be a simple swap that will only take 5-10 minutes. I was concerned that resetting the ecu would cause some other issues and trigger and error code.
Old Jan 2, 2007 | 03:15 PM
BoanHed's Avatar
BoanHed
Is the battery disconnect methoda FULL reset back to factory settings?
I am asking specifically about things like rev limiter, spedo calibration, etc.
Old Jan 2, 2007 | 04:23 PM
Shelbyville
Wish I knew. Thats why I am hesitant to do it. Don't want to fix something thats not broken.
Old Jan 2, 2007 | 04:37 PM
ASUSMC's Avatar
ASUSMC
No it won't ruin a tune if you have a custom tune. Its just like unplugging your computer at your house. When putting mods on your car it is essentially the same thing of putting a faster DVD/CD-rom on your computer. The information is still there.
Old Jan 2, 2007 | 05:04 PM
AJ06GT's Avatar
AJ06GT
ORIGINAL: ASUSMC
I would have explained it as ROM and RAM, but yours is better for less "techie" people haha.
