Patriot Stage II Heads.
RE: Patriot Stage II Heads.
ORIGINAL: code3GT
I would not buy Patriot. Too many quality issues. I researched them quite a bit and it's hit or miss with their quality.
www.vtengines.com
ORIGINAL: Rantheman
you see i am not the only one against them plus a 5 angle valve ob don't do any better than a 3 angle valve job I would do like code suggested frpp heads livernois or vt over patirot
i dont believe the SVO/FRPP were stock 2v heads, i might be wrong though, but they have different positioning of walls by the inlet valves, valve centerlines were moved closer to the center of the bore. I didn't know you could change that from a stock 2v head unless I'm wrong?
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 09:06 AM
