how to tell if you have pi intake
RE: how to tell if you have pi intake
Nope. Ford made maifolds with aluminum cross overs for the non PI cars. You can tell this way. On the non pi manifold the front intake runner is on the passenger side. On the pi manifolds the front intake runner is on the driver side. By front I mean closest to the front of the car. The pi manifold is also taller.
Also you can try looking in the valley between the cylinder heads. If you have a coolant hose running underneath the manifold from the water pump it's most likely a npi manifold. When I did the swap I had to run the coolant line on the side because the plenium is alot larger.(deeper)
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
